Popping out of 3rd gear, NV4500
Old Jun 16, 2007 | 09:09 AM
GFB's Avatar
GFB
Sometimes the trans pops out of third. Not under acceleration, just like slowing down going over railroad tracks, around a corner, etc. If I don't pull it down into 4th or 2nd first, it will grind if I try to put it directly back into 3rd gear. I guess it isn't pulling past the synchros unless I switch gears first. Is there a shift stop I can adjust or is it just starting to show its age? Tranny has about 125k miles on it.
Old Jun 16, 2007 | 07:01 PM
J Lent's Avatar
I just went through the same problem....bad synchro. There is no adjustment. I would recommend ordering a set of brass synchros from Blumenthal. www.blumenthalmfg.com The tranny shifts like new now & the brass lasts longer too. If you have a rough shift....at 125k on the clock your detents may need changed also.
Old Jul 2, 2007 | 10:36 AM
wadecool's Avatar
I had trouble with 5th gear falling out of gear whenever I let off the throttle. I lost it soon after so you ought to have it looked at.
whitepowertruck
Apr 24, 2014 08:02 AM
thrub
Feb 20, 2014 12:57 PM
J Lent
Apr 16, 2007 08:31 PM
Toby
Oct 25, 2005 10:47 PM
dodgeram
Nov 26, 2004 09:10 PM
