please be patient
Old Feb 20, 2003 | 09:44 AM
zoomie72's Avatar
please be patient
please be patient with me as i am a new forum user and new CTD user/son of owner ;D had ?'s about possible problems to watch for related to the engine,trans,transfer case,etc.just bought 2001.5 ctd ho 6spd 4x4 drw w/67k miles on it 8).kinda wanted to catch problems sooner than later.
thanks in advance,zoomie
Old Feb 20, 2003 | 09:51 AM
Iron Horse's Avatar
Re:please be patient
Hey! Welcome to the DTR! <br><br>The best suggestion I can think of is to install a set of gauges. EGT, Boost, and Fuel Pressure. <br><br>The fuel pressure gauge is the most important in my opinion, as all of the 24V trucks have the chance of the electric lift pump going out. A gauge is cheap insurance to save your VP44.<br><br>There are a lot of good guys on this site, and we will all gladly help ya.
Old Feb 20, 2003 | 10:00 AM
BigK's Avatar
On the whole, the Dodge/CTD seems to be a reliable combination. Due to the nature of this site, however, it might seem that they are riddled w/ problems. There is a great deal of in depth discussion with respect to many items that have had a higher rate of failure.
One of these items that can affect anyone, modified or not, is the fuel transfer pump. Failure of this pump can lead to the failure of the injector pump. A co$tly repair. A fuel pressure gauge is highly recommended to monitor the pressure, and thefore diagnose a weakening transfer pump before complete failure.
Welcome to the site!
edit - guess I gotta learn to type faster ;D
Old Feb 20, 2003 | 10:58 AM
zoomie72's Avatar
thanks for the info.would i be better off to replace the lift pump whether or not it was a problem,or has the maker not fixed the replacement.
Old Feb 20, 2003 | 07:37 PM
rich's Avatar
just put a pressure gauge on it and check it , your still under warranty till 100k form that part the spec's say that it should not be less then 8 psiat wot. if it is less then 10 its weak at WOT at idle it should be around 15. you'll have to convince the dealer that its bad to get replaced under warranty . if you want to replace it yourself then buy it from cummins they are cheaper
DHT
Apr 2, 2010 07:12 AM
pokapotato
26
Feb 21, 2009 01:39 PM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
