Fuel pressure line question
Old Feb 20, 2003 | 01:13 PM
MARKY MARK's Avatar
I am doing fuel pressure guage install tomorrow. On my '99, how does the grease gun hose hook to the top of the fuel filter housing? Also installing boost guage & pyrometer guage. Any suggestions on how to make the install on all these go smooth would be greatly appreciated.
Old Feb 20, 2003 | 07:30 PM
rich's Avatar
Re:Fuel pressure line question
their are 2 plugs in the top of the filter housing one is pre filter the other is post filter. i hooked mine up post filter in order to see what the inj. pump is getting. its pretty easy after i drilled the hole for the line. the other gauges i dont have yet so i cant help you their sorry.
Old Feb 20, 2003 | 08:59 PM
Idaho CTD's Avatar
If you want it to read post filter pull out the 1/8&quot; npt plug that is towards the front of the motor. The grease gun hose will screw right in.<br><br>For egt guage installs I back the turbo off and use masking tape over the turbo holes. This keeps all the metal pieces from getting into the turbo and it makes it easier to run a magnet in to fish any loose pieces out. If you take the top two turbo nuts off and loosen the bottom two you can pull the turbo back until it catches on the manifold studs.<br><br>The boost guage depends on how you are tapping into the system. I use the plug in the intake manifold next to the map sensor. I think it uses a 1/2&quot; ratchet and a extension to remove it. It might even take a breaker bar if it has been in there awhile.<br><br>Have fun<br>Nathan
quicksilvr
Jun 23, 2011 11:30 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
Sixpack73
Aug 21, 2007 10:51 AM
Flatty
Jan 5, 2005 02:50 PM
