Pinion Nut Size?
Old Jan 19, 2003 | 12:21 PM
BigK's Avatar
Re:Pinion Nut Size?
I believe in utilizing correct torque values whenever possible, but I too lack a torque wrench w/that capacity. 3-4 foot pipe on the 3/4 drive breaker bar &amp; give a tug. <br><br>Or you could use above info. <br><br>Over 250 and you should be fine. A drop or two of blue loctite would not hurt either.
Old Jan 18, 2018 | 02:03 PM
Whitedodgeramfa's Avatar
Do you now what Brand you used to take off the yoke
Old Jan 24, 2018 | 12:28 PM
Busboy's Avatar
Snap sells a 4ft long 1 inch drive 0-600ft lbs torque wrench and let me tell you pulling 600ft lbs even out in the open is pretty tough, we mostly did it with two people. For just replacing pinon seals I've always used the 2 center punch/ dot method, just line them up again when tightening.
1985cucv
Jul 16, 2009 10:49 PM
Purplezr2
Dec 3, 2007 09:59 AM
CTD NUT
Mar 8, 2005 08:32 AM
ATEAV8GN
Jan 13, 2003 03:24 PM
