P1688 code help
Old Jan 11, 2013 | 11:36 AM
conroediesel's Avatar
P1688 code help
hey guys, well my 98.5 2500 suddenly died on me the other night and wouldnt start back up. i got out let some fuel out of the filter and it started right up it idles fine but when i give it and gas it starts missing and shuttering it was throwing the code P1688 (internal fue injection pump controller failure) not sure what to do any help would be great
Old Jan 11, 2013 | 03:27 PM
Mechanos's Avatar
Sounds like the VP44 is dead. Time to replace it and upgrade your lift pump if you haven't already done that.
Old Jan 11, 2013 | 11:54 PM
thats what i was afraid of.... i just ordered a new lift pump today. i got the fass stock replacement. any suggestions on the vp44? i heard blue chip is a pretty good place to order one
Old Jan 12, 2013 | 10:06 AM
Tallguy67's Avatar
Here is a link to the best VP44 diagnostic site I have found yet.
http://m.bluechipdiesel.com/site/vp4...ostichelp.html
Old Jan 12, 2013 | 06:27 PM
rickf's Avatar
I just put on a DDRP today and it is no good! 10 LBS. at idle and 4 lbs. at MILD acceleration. My old beat up stocker was doing a lot better than that but was failing electrically. I hope I just got a bad one because they are probably just going to want to replace it with another one.
Rick
Old Jan 12, 2013 | 11:25 PM
Mechanos's Avatar
Rick
I consider the crank-driven mechanical lift pump I put on my truck one of the best mods I've done. 18 psi at idle... 20 psi under any type of acceleration. Couple that with a "big line" kit and I've pretty much got it covered.
Old Jan 13, 2013 | 07:38 AM
rickf's Avatar
I wanted to go that route but the funds are just not there right now. This happened at a bad time. Having the truck down for two weeks and now three weeks is hurting me even more. I can't believe that in 13 years nobody has been able to come up with an AFFORDABLE answer to this problem. Fuel injected cars run on electric pumps for hundreds of thousands of miles and we can't get 10,000 miles out of one.
Oh, You can buy replacement low pressure gasser pumps for 15.00! Super high performance ones cost 225.00.
What is the reason you cannot use a gasser pump for diesel?
Old Jan 13, 2013 | 09:54 PM
oldkimmer's Avatar
...........i've been running a Holley Blue pump for 5 years now......i have 4 in exhaust and the edge ez...kim.....
Old Jan 13, 2013 | 10:02 PM
torquefan's Avatar
I feel your pain, but have to add that even on gassers, the number one failure of most vehicles is also the fuel pump.
Working on diesel trucks for years, I noticed that one of the most durable lift pumps was the electric pump on 7.3 powered Super Duty trucks. Never personally tried it, but always thought it might be a reliable part to retrofit onto 24 valve and common rail Dodges, if a guy could come up with a decent way to regulate the pressure to something we could use.
Ramdrivenchick
Sep 4, 2008 08:49 PM
bankspwrdodge
May 1, 2007 08:15 AM
bankspwrdodge
Apr 30, 2007 10:19 PM
Terraizer
Dec 14, 2005 03:56 PM
Terraizer
Dec 10, 2005 05:55 PM
