P0500 code.
Old May 30, 2010 | 07:41 PM
77machomopar's Avatar
P0500 code.
I have that code in the computer and i am wondering where the sensor or sensors are located? its a rear drum brake axle with abs and ab auto trans. thanks
2001 QCLB 4x4 auto
Old May 30, 2010 | 09:16 PM
BigIron70's Avatar
Cummins Guru
Located on top of rear diff housing.
Old May 30, 2010 | 09:21 PM
johnh's Avatar
2001 QCLB 4x4 auto
the 0500 code is telling you the drive wheels were spinning without forward motion,or more likely the engine was running at a high idle for an extended time.......nothing to worry about
Old May 31, 2010 | 05:16 AM
ok i was hoping that it had something to do with the O/D portion of the trans. cuase it jsut wants to keep hunting between 3rd and OD
Old May 31, 2010 | 09:49 AM
rebal's Avatar
it might just be a dirty ground or a weak alternator casing the hunting thats common to happen .and like was said P0500 is no biggie it happens on mine all the time
Old May 31, 2010 | 07:58 PM
i found out the cause to the p0500 code. the trans output speed sensor was cracked apart. So i replaced that today and that trans still hunts quickly between gears and i have to let off the throttle for the trans to shift gears. thanks
lovinCTD59
Feb 10, 2007 01:59 AM
dssimecek
Jan 24, 2006 12:54 PM
K2Cummins
Dec 24, 2004 09:41 PM
figure_9_pro
Dec 5, 2004 08:29 AM
More Power
Jan 20, 2004 10:58 AM
