P0251 P0252 Question
Old Nov 29, 2010 | 03:19 PM
rynojr4644's Avatar
I have this code popping up on my 2000 2500 24 valve? I had to drop my tank a week ago because there was water in my fuel. We broke the return line on the sending unit so for now I put it in the over flow back to the tank. I do not think the tank has a vent right now other than the cap.
The truck runs fine was running the return line in the over flow off the neck what threw these codes out?
Mods:
150 injectors
4" exhaust
blue chip box
Aftermarket turbo of eBay works great.
Air dog 150
Cold air intake
Old Nov 29, 2010 | 03:56 PM
dkenny's Avatar
did you try draining the fuel filter??
I don't it matters where the fuel is returned to the tank..
just look at an AD setup..they add a return to the fill tube.
-dkenny
Old Nov 29, 2010 | 04:03 PM
rynojr4644's Avatar
This is the stock return line not the Air Dog. ? Thanks
Old Nov 30, 2010 | 10:22 AM
rynojr4644's Avatar
Codes went away and now the truck is cutting in and out when trying to get up to speed? Even though I have a Airdog do you think the lift pump is going out?
Old Nov 30, 2010 | 03:10 PM
Junk Man's Avatar
Do you have a pressure gauge?
Old Nov 30, 2010 | 04:03 PM
rynojr4644's Avatar
We found the return line had a kink in it is running good now will let you know.
Old Nov 30, 2010 | 09:04 PM
dieselautopower's Avatar
those are both failing VP44 codes
clear the codes and see if they go away.
Old Nov 30, 2010 | 09:39 PM
65sixbanger's Avatar
So How did you get the kinks out of the the return line???
Mine is doing the same exact thing, I dropped the tank to put a draw straw in and, and witht the new lift pump, it ran like crap.
Old Dec 1, 2010 | 10:35 AM
Junk Man's Avatar
Guys, you need to know and monitor fuel pressure. I intend to add an idiot light IN ADDITION to my mechanical gauge. I can't watch the gauge every minute & figure a light would call attention to the gauge.
Old Dec 3, 2010 | 08:08 AM
rynojr4644's Avatar
It was the return line on the stock system was kinked at the tank , no more codes. HAPPY HAPPY HAPPY.
cummnz4x4pwr
Oct 28, 2005 09:21 PM
Stevenc
Feb 27, 2005 06:48 PM
converteddzlr
Oct 25, 2004 01:40 PM
AUTO-5
Jul 9, 2004 02:23 PM
Robin Shaw
Nov 24, 2003 02:16 AM
