overserviced tranny !!!!!!!!!!
Old Jul 30, 2005 | 04:31 PM
airplaneman00's Avatar
i have been noticing my tranny acting up lately, if you go to the HELP forum, you can see the symptoms.. but i pulled the dipstick the other day and noticed it was above the max line, what could this cause. it is about a 1/4 inch above the line. and how much do you think that is in fluid form. meaning how much should i drain out
steve
Old Jul 30, 2005 | 05:26 PM
SilverRam01's Avatar
Steve;
You may already be aware.....your transimission fluid level should be checked with your engine running, and in neutral. If your in park,......you will get a much higher reading. If your fluid level is 1/4 inch above the line, with the trans in park,.....you are likely low on fluid.
Warm it up,......and check it on level ground, with you transmission in neutral, this will give you the most accurate reading.
Old Jul 30, 2005 | 06:49 PM
Stamey's Avatar
I have overfilled mine before, and never gave it a second thought. Don't worry about overfull, if it's just a little. But make sure you measure it as SilverRam suggested.
Chris
Old Jul 31, 2005 | 07:26 AM
this is witl it running in neutral. just like it is supposed to be. i am just trying to figure out why i am having these tranny problems. thought maybe that would be an easy fix... let me know if you can think of anything else. see my post in help section for symptoms
steve
Old Jul 31, 2005 | 05:57 PM
bmoeller's Avatar
A little extra fuid won't hurt you. Just leave it in there. As long as the oil isn't foaming up, you'll be fine.
*** I also posted in your other thread.
Old Aug 1, 2005 | 05:31 PM
well i guess i will make some phone calls and maybe bite the bullet and take it to the shop. hopefully it is something like linkeage. thanks....
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
