HELP!!Why does my CTD "nose over" at 2200rpms??
Its like it floats the valves.We own 5 CTD's(93-99,160-450k
) and they dont seem to do it till the milage gets up there(150k+)The 12 valves float at around 1700 I think....Been a while since ive driven any of them.I inherited the trucks from my father and when I drove the 99 last week,it did this.Under 2200 and its fine...
Im about to start driving/modding the 99 ext cab 5 speed 2500 work truck and I want to get it running 100% before I start driving it.
I want to go as fast as the stock turbo will take me.Maybe another turbo down the road but not likely.I already have 2 GN's,I just want somthing thatll still show those pesky ricers theyre weak WHILE towing a GN
BTW,been a lurker here for a while and the sites great BUT YOU GUYS NEED A STICKY WITH WHAT ALL THOSE ABBREVIATIONS MEAN!!!I dont know one part from the next and it seems the search is down...
) and they dont seem to do it till the milage gets up there(150k+)The 12 valves float at around 1700 I think....Been a while since ive driven any of them.I inherited the trucks from my father and when I drove the 99 last week,it did this.Under 2200 and its fine...Im about to start driving/modding the 99 ext cab 5 speed 2500 work truck and I want to get it running 100% before I start driving it.
For a description of the abbreviations look here:https://www.dieseltruckresource.com/...n&onlynewfaq=1
What do you mean when you say the 12v engine 'floats' at 1700 rpm? Generally the governor in the pump starts to de-fuel at about 2200 rpm. Is that what you are feeling?
Tom
Tom
Thanks for the link...
What I mean by floats is it seems like it floats the valves,like a gasoline engine w/ a hyd cam.
None of our CTD's will hit redline like they did when newer(under 150k)
I just ordered a FASS and full MBRP exhaust so well see how those 2 help out.
You won't like this!
I had my CTD in to the dealer today to have my IP replaced. I was talking to mechanic and he was explaining to me the symptoms of a failed IP. Guess what? He said one of the more common symptoms is "can't rev over 2200 rpm". Very similar symptoms to yours.
Re: You won't like this!
If those dont fix it,ill replace the IP.
I want a fire breathing Cummins
BTW,how does the timing "slip"?
I bought my 99 Cummins Dodge with 36000 mi. and it never has gone over 2100 RPM no matter how hard I try. It now has 56000 and I lost the tranny today. About 3 months ago I replaced the lift pump. So are you guys saying it should go over that RPM? I know that is dumb ? but no one has given me a straight answer so far locally. And anyone have any suggestions for a tranny?
I dont know what I would do if I couldnt get my truck over 2200 rpm. I love to watch the expressions on peoples faces when they have their drivers window down and I downshift into 3rd at about 30 mph
I would say there is there is a problem with the IP but thats just an educated guess.
RPM Limit
The CTD engines will rev to 3450 rpm +/- 50, determined by the rev limiter, 2200 rpm limit is a problem. According to the diesel mechanic working on my truck " (he replaced my IP) one of the most common symptoms of a IP failure is the inability to rev over 2200 rpm".
Check your codes there should be none. If you have a 216 code this is death code for IPs. If you have no codes or even if you do take it to the dealer and have him check it. You don't have to have the work done but it will determine where the problem is.
Good luck
Grim Reaper.
Good luck
Grim Reaper.
dieselfuelonly
Nov 3, 2007 02:04 PM
