Overboost problem?
Overboost problem?
I checked for codes today because I had a dead pedal issue and got the dreaded 216 code and the 236.I've been reading that the 236 is an overboost condition and it throws this code if boost has reached over 20psi.My truck always goes 24-25 psi when matted.Could this be a map sensor problem? or do you have any suggestions?
The truck ran fine after I turned it off and restarted.
Is this kinda like what a jhook does and some people want this with a boost fooler?Ken
I think you might have hit the nail on the head.Thats exactly why I thought my vp44 was going.When it wound out to pass lets say,It would start to fall on it's face which made me think it was weak.I will be checking it out tonight.
If you go underneath and look up you will see the shaft going into the turbo. You can spray it with a penetrant and free it up. If you are going to run a box on it leave it stuck. My 2002 runs about 35 to 38 pounds of boost with the super chips programmer. Before I had it chipped it would start derating at about 24 to 26 pounds of boost. It just ran like at dog at 1/2 throttle or more. Idle and light throttle it ran fine. Not an uncommon problem.
That is the problem.It is siezed solid.I han a wrench on it and barely got a wiggle.I sprayed the crap out of it and I'll wait to free it up tommorrow.Thanx for the great info I hope I build enough knowledge to help you someday.
Got it all freed up today and drove it through all kind conditions from city to long highway.WHAT A DIFFERENCE.It doesn't fall flat when I pass and my boost stays much lower on the highway cruise.Thanx again for the great info.
Glad to hear it worked out for you. Most fixes are simple on a diesel if you understand them.
johnshole
0
Jul 13, 2005 10:42 AM
high country
Mar 24, 2005 10:52 AM
psalm69
Sep 13, 2004 06:34 PM
