oil pan gasket replace?
Old Jan 4, 2010 | 06:04 PM
1bad93's Avatar
im looking at a 98 24 valve and it needs a oil pan gasket. so my question is how easie is it to replace. ive done an older ford befor and you had lift the engine to get to it. so i really dont know if i would want to go through the trouble of buying a truck that i have to remove the engine of.
Old Jan 4, 2010 | 06:20 PM
nickg's Avatar
Before replacing the oil pan gasket, check to make sure the bollts have been re-tightened, they do and will loosen off,and tightening them will stop a leak. also most diagnoise an oil pan leak especially if leaking on the drv side, the vacuum pump seal will leak and so does the lifter cover (big cover on the side of the engine), both will run down over the oil pan gasket giving the appearence of a leaking oil pan gasket
ChrisG
Jun 29, 2008 09:19 AM
tex23455
Jul 25, 2007 02:31 AM
bostongsx
Sep 25, 2006 11:25 PM
Common
Aug 24, 2006 06:31 PM
ewatts2003
Jun 24, 2006 07:51 AM
