oil leak right under the crank pulley
I have an oil leak on my 2000 cummins
i have already rebuilt the vacuume pump and fixed that awfull eak but this one i have found to be coming from right under the crank shaft pulley
slow leak not really bad but leaves a puddle none the less and since i rebuilt the vacuume pump im on a mission to make it stop leaking if i can
so any guesses on what i need to do or what parts i need
i understand that my timing cover doesnt use a gasket on my truck but the timing cover housing which is directly behind it does so im not sure how to go about this problem
Roberts probably right...Front Crank seal, possibly the timing cover gasket, since it is kind of hidden under the crank pulley.
The Front crank seal isn't that hard to replace, the hardest part is getting the crank pulley off, your home free after that.
alread got rid of the breather bottle and routed it away from front of engine so i know it isnt that
looks like ill go with the front crank seal
any specil tools i might need for getting that thing off????????
1985cucv
Dec 19, 2009 12:48 PM
NoSparkplugs
Feb 26, 2006 08:17 PM
