Not charging
Old Jan 21, 2008 | 07:47 PM
YJim's Avatar
Not charging
P1698 and not charging. No other issues such as dead tach. All gauges are working and CEL is off. This condition was caused by a front end collision. Any ideas?
Old Jan 21, 2008 | 08:50 PM
Tate's Avatar
I'd say pull the alt off and have it checked to see if its still good.
Old Jan 22, 2008 | 07:50 PM
dozer12216's Avatar
Assuming your alt tested good at friendly parts store.
With engine running (CAREFULLY) test voltage at green wire(?) of two wire connector. It should be approx bat. voltage. IF not bat voltage you may have damaged wire from relay or bad relay or fuse in PDC.
Now with terminal connected and engine running (CAREFULY) test voltage on blue (?) wire. If the voltage is still approx bat voltage, the wire to PCM (right side cowl) is open or PCM is not controlling rotor field.
Color of wires may vary. One supplies current to rotor and other controls rotor field strength.
Old Jan 23, 2008 | 12:51 PM
YJim's Avatar
Alt. tested good. The body shop is sending it to the dealer to diagnose and repair the 1698 issue. While it's at the dealer, should I tell them I want NO computer flashes? Are there any GOOD flashes that I need to get caught up with (besides hi idle/ 3 cyl. idle)? Dealer hasn't touched it since '01. I'm kinda spooked that they are going to have their hands on it...
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
matchhead
Apr 19, 2005 06:13 PM
Beerrunz
Mar 1, 2005 02:06 PM
