Not charging
Old Mar 1, 2005 | 12:38 PM
Beerrunz's Avatar
Unhappy Not charging
Having problems with a 97 5-speed. Have replaced alternator, checked all external fuses and still cannot get it to charge. Any ideas other than replacing the ECM at a huge cost!!
Old Mar 1, 2005 | 01:54 PM
RAM2940's Avatar
Have you taken a multi-meter across the battery terminals to verify that you have 14vdc. If you do then time to start looking for something that has shorted.
Old Mar 1, 2005 | 02:06 PM
MnTom's Avatar
It could be anything from the Crankshaft Position sensor to a blown fuse for the alt. You didn't just get done changing the oil did you? If you accidently hit the terminal on the back of the alt. you will blow a fuse. Try reading this thread and see if it helps: https://www.dieseltruckresource.com/...tage+regulator
There is even instructions there how to by pass the ECM and install an external voltage regulator.
Tom
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
miningman
Nov 2, 2005 07:34 PM
matchhead
Apr 19, 2005 06:13 PM
