4 low pulsates oddly
Old Feb 27, 2005 | 06:13 PM
mr T's Avatar
i was in a parking lot today just just going through the 4 by 4 gears with the shifter because i lubed up the linkage underneath...i never use 4 low so i thought im gonna just op it into 4 low and drive slow for a few meters to see if 4 low is still alive ya know?...so i put it into 4 low while in neutral and put her in drive and idle away....it pulls quite a bit just idling which im sure is normal...BUT it was pulling me forward in PULSES...it wasnt a steady drive...it was rythmiccally pulling me and not pulling pullin and not pullin....in 4 high it behaves perfectly normally
just wondering what i should check or what i should be looking for as normal driving behaviour in a straight line with the 4 low....it almost felt like it wasnt fully engaged or something but there was no grinding or anything and no vibration either
Andrew
Old Feb 28, 2005 | 12:37 AM
P.O.R.'s Avatar
did you try giving it a little throtle to see what would happen, i think it would smooth rite out if given some steady pedal pressure....
Old Feb 28, 2005 | 03:42 PM
G1625S's Avatar
With the steeper 4lo gearing, the inherent lash in the drivetrain will be more noticible...my guess is you're feeling the sum of the differential lash, driveshaft ujoint lash, driveshaft slip yolk lash, transfer case lash...the list goes on---kinda like pedaling a 10 speed bike up a steep hill---in first, you can feel each pump of your legs, but in, say, 6th or 8th gear, if you have the strength, the motion is smooth.
greg
Old Mar 1, 2005 | 09:39 AM
mr T's Avatar
i think you know exactly what im talking about....im glad that its normal..i never spent time in 4 low so i had no idea what to expect thanx G1625S
Andrew
Old Mar 1, 2005 | 02:39 PM
jrs_dodge_diesel's Avatar
I have noticed similar symptoms in my previous 4x4 vehicles. In my old F150 especially since I had a broken tranny mount.
Old Mar 1, 2005 | 06:22 PM
G1625S's Avatar
I tend to get nervous over every little lurch, squeak, rattle and bump (of which my truck has MANY ), but when it comes down to it, these trucks have some pretty serious drivetrain components and, unless it just stops dead with a pool of fluid under the offending part, it's prolly just part of the program that comes with owning a no-nonsense piece of machinery
rjm022
13
Jun 9, 2023 06:34 PM
rbrettctd
Apr 23, 2007 01:23 PM
Breck-Ram2500
Jun 2, 2006 07:47 PM
spitzair
Jan 24, 2006 03:42 PM
Deezwillfither
Mar 23, 2004 11:06 PM
