No start park
Old Jul 16, 2016 | 02:26 PM
mitm's Avatar
No start park
Hi all,
After truck sits for while wont start. Sounds just like dead battery, just click.
Move the shift lever to neutral, back to park, fires right up.
Old Jul 17, 2016 | 11:40 AM
SIXSLUG's Avatar
Bad neutral safety switch I'm thinkin, might be called something else, but sounds right.
Messed with anything around its location lately?
Old Jul 19, 2016 | 08:41 PM
Humblecowboy's Avatar
My 99 did something similar about 3 weeks ago except I had hot batteries and the engine spun over real good but no fire. two hours later went out and for kicks turned key on, shifted to neutral or drive then back to park. Hit start and it fired right up as normal. Only happened that one time. We had been having a lot of damp rainy weather down here in East Texas and I'm thinking it has caused a whole mess of electrical issues with the truck. I am posting a novel on my TC lockup issue in a new topic. Going to go cry now. :-(
Old Jul 20, 2016 | 10:30 PM
SIXSLUG's Avatar
It's damp up here 9/12....did you dip it or go through deeper puddles?
If you have success after moving the shifter, I'm thinkin a switch is bad.
Old Jul 21, 2016 | 07:45 PM
Thank you for the reply and help SIXSLUG. Haven't been dipping it and I stay out of water where I can't see the road. On the no start, can a bad switch let the engine spin over but not fire??? I'm wondering also what role the PCM plays, if any, in the ignition system because I posted in another topic about my TC lockup issue. I'm going to disconnect the leads and flush them with contact cleaner and see if that solves the problem.
Thanks again for your help, Frank
terryKS
Aug 19, 2013 11:46 PM
stackit02
May 10, 2010 11:29 PM
CoolumConst
Oct 11, 2008 10:00 PM
Begle1
Sep 1, 2005 10:34 AM
wick
Jan 2, 2003 02:50 PM
