no HEAT
Old Nov 5, 2006 | 12:14 AM
getblown5.9's Avatar
Angry no HEAT
well as the first cold spell is upon me here...i found out tonight with temps in the mid 20's that my heat no longer works in the truck. it was a cold 30 minute drive home, with engine temps right up at 190 where they should be...the air coming from the vents may have been 60 degrees tops...it just isnt hot like it should be. the heat has always been able to make it so hot i cant breathe and now its
so anyway i checked heater hose for a kink that wasnt allowing flow...looks good. the controls for metering heat seem to work because it will work fine on the cold side but when going to the hot side it just doesnt warm up.
i had some heater core noise like there was air in it...had that noise for nearly 2 months since doing the head, im thinking this air is trapped in there preventing the hot coolant from flowing properly.
any ideas?
Old Nov 5, 2006 | 07:12 AM
displacedtexan's Avatar
A TOM without heat? What is the world coming to??
I would check for air in the heater core, not real sure how, but that seems to be the most likely cause. Or maybe the blend door is stuck. Or partially stuck.
Old Nov 5, 2006 | 08:27 AM
Mopar1973man's Avatar
Here is a few ideas...
Originally Posted by DODGE FSM BOOK
OBSTRUCTED COOLANT FLOW Possible locations
or causes of obstructed coolant flow:
² Faulty water pump.
² Faulty thermostat.
² Pinched or kinked heater hoses.
² Improper heater hose routing.
² Plugged heater hoses or supply and return ports
at the cooling system connections.
² A plugged heater core.
If proper coolant flow through the cooling system is
verified, and heater outlet air temperature is still
low, a mechanical problem may exist.
MECHANICAL PROBLEMS Possible locations or
causes of insufficient heat:
² An obstructed cowl air intake.
² Obstructed heater system outlets.
² A faulty, obstructed or improperly installed
blend door.
² A faulty blower system.
² A faulty a/c heater control.
Or...
TEMPERATURE CONTROL
If the heater outlet air temperature cannot be
adjusted with the temperature control **** on the
a/c heater control panel, the following could require
service:
² A faulty blend door actuator.
blend door.
² The engine cooling system.
tswcoaltrain
Nov 12, 2019 09:11 PM
bkrukow
Apr 29, 2011 06:42 PM
crossy
Dec 5, 2002 10:42 AM
crossy
Nov 1, 2002 05:16 AM
DieselDaze
Oct 25, 2002 06:50 PM
