1693 code=dead truck
Old Nov 4, 2006 | 10:24 AM
genesis's Avatar
Driving down the road last night truck died...Started right back up but will only idle, when you press on the throttle it runs really bad and sounds like its about to break in two.
Checked the codes with the key trick and it only shows 1693.
Any ideas?
Old Nov 4, 2006 | 10:54 AM
blackdiesel's Avatar
Registered
you will need to get the rest of the codes pulled 1693 just tells you theres more codes. I think you will find a 0216 cross your fingers and hope not. It could be a apps. do the rest and hope for the best
Old Nov 4, 2006 | 11:06 AM
genesis's Avatar
I'm trying to pull the code right now, my Auto Enginuity scanner will not connect to the truck for some reason.
Old Nov 4, 2006 | 11:12 AM
Registered
try the key agian, I've seen it read it the 2nd time, where it didn't
the first
Old Nov 4, 2006 | 11:28 AM
genesis's Avatar
I tried the key several times...still ony shows 1693 and the engine light.
Anyone have auto enginuity scanner that might be able to help me hookup?
Old Nov 4, 2006 | 11:46 AM
Registered
I have a smarty that will do it, BUT your a long ways away. You might try your local parts store they might help you out. Do a search an the apps reset and try that. Can't hurt any thing
Old Nov 4, 2006 | 02:59 PM
J BODY's Avatar
Unhook your "toys" and see what happens.
Old Nov 4, 2006 | 03:13 PM
crobtex's Avatar
Toys......... I like that!
Old Nov 4, 2006 | 05:36 PM
J BODY's Avatar
Feel free to use it anytime you like .
...just made me think of the Edge EZD1000c I have laying on my bench. Every once in awile a truck I was looking at would run like crap and set a rail psi fault code. Been running great for a month now with the box off of it. We were going to send it in to have checked, but I think he's looking at going with a stronger TST set up.
Old Nov 4, 2006 | 08:14 PM
genesis's Avatar
unhooked the "toys" and it still does the same thing.
Cracked the injectors and it takes forever to get even a little fuel out of them.
When it does start, it idle like crap and barely does anything when you press on the pedal.
I got a scanner and came up with a 1688 code.
Old Nov 4, 2006 | 08:24 PM
Registered
that is even worse than the 0216. you are in the market for a new injector pump (vp44) sorry to be the one to have to tell you the bad news
Old Nov 4, 2006 | 08:38 PM
01 2500's Avatar
im having a similar issue but im getting a 1689 code still looking for fix
Old Nov 4, 2006 | 08:55 PM
Registered
well 1688 is internal pump failure where 1689 is no connunication between the ECM and pump, check the plug on the pump
Old Nov 5, 2006 | 10:34 AM
J BODY's Avatar
Yep! It sounded like a pump issue, and the 1688 verifies that. Happy shopping!
Being you are in AZ give SW Diesel a call in Phoenix.
Steve V.
Nov 30, 2008 03:10 AM
600 Megawatts
Mar 26, 2008 07:09 PM
Gene007
May 16, 2004 05:55 PM
j
Mar 9, 2004 11:45 AM
roadrat
Jan 18, 2004 03:07 PM
