No Fuel Return? - 24v Yanmar
Old Nov 11, 2010 | 08:51 AM
high bid's Avatar
I have a 24v Yanmar, they're almost identical to the CTD except there is a belt on the front instead of all gears. The issue is there is no fuel coming from the return line. This motor has 1hr on it and basically brand new (the other one returns fuel w/no problem). The pump, injectors and everything have been check prior to reassembly. Plenty of inlet LP psi but no return of fuel. Fuel path is:
LP-filter-IP-injectors-fuel return line-2way banjo on the back of the LP-fuel cooler-return to tank
Flow to the IP pump is good and I've blow air thru the cooler at the end of the fuel return line but no flow to the cooler. Where could all the fuel be going as I haven't seen an increase in the oil? I'm thinking the banjo bolt may be stuck and/or restricting things but any ideas would be appreciated.
Old Nov 11, 2010 | 06:43 PM
TurboDeezul's Avatar
Where did you get it? Do you have a picture of it you can post? I didn't know the CTD was copied by anyone.
Old Nov 11, 2010 | 09:14 PM
Junk Man's Avatar
Just surmising. Does it have the T at the back of the head? Overflow valve stuck closed?
What is your yanmar in?
Old Nov 12, 2010 | 08:03 AM
high bid's Avatar
tubo-actually the motor is made by Toyota but almost identical on the front end except belt driven. Because it's for marine some of the components are a little different and relocated on the motor so its compact.
junkman-yes the metal return lines comes directly out of the head towads the front, not the back and goes to the back of the IP thru a banjo bolt and T there. I'm going to try to take it apart Sunday as the T is the only place I can think of being the problem. The twin yanmars (6cyl/325hp) are going back into a sportfishing boat.
Old Nov 12, 2010 | 12:18 PM
Junk Man's Avatar
Yanmars were used on some sailing boats. I have one of the smaller boats from the 70s. Unfortunately, mine came with a gasser. Perhaps it is better because I only use the motor to get out of the harbor on a land locked lake.
Old Nov 12, 2010 | 12:20 PM
high bid's Avatar
True and many convert gas to diesel and using Yanmar for their weight/hp ratio and economy.
G1625S
Jul 27, 2012 06:25 AM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Dodgecaveman
Jun 22, 2005 12:11 PM
DieselDaze
Dec 22, 2004 04:54 PM
