No 5th gear in my nv5600 after rebuild
I have an 01 truck with the nv5600 transmission and 150000 mi I was replacing my clutch so I decided to rebuild the trans while I was at it,, I put it all back together and 1,2,3,4-6,r all shifted perfectly and smooth but I couldn’t get it into 5th occasionally I could get it in 5th just a little but when I let the clutch out it would kick out and grind I’m thinking it’s something in the shift rails assembly I took it back out can’t find anything wrong I did add a endplay shim to tho counter shaft cause there was a little to much play is there anyone that could help me out I would appreciate it very much also I don’t think the correct fluids are much of a problem for anyone but I used synchromesh from my cousin who owns Blake’s diesel care so I’m pretty sure it’s the better option
Stealth Mode
11-23-2005 07:52 AM
