New VP44 and lift pump and blinking fuel light
Old Jul 22, 2009 | 08:35 PM
Wilbur01's Avatar
I installed a new Vp44 and a new stock lift pump last week. I just installed the Fuel pressure LED kit today. I took it for a test drive and the light in blinking (flickering) when I am going. It is not as strong as when it is full on like when I turn the key on. Does this mean low pressure already????? I am not sure what to replace from here. I will get some sort of gauge tomorrow but I need to get this fixed ASAP, I am leaving on a trip on Friday and thought my problems were over and I don't know where to pick up a FASS in MN?
Old Jul 22, 2009 | 09:05 PM
Dr. Evil's Avatar
You need a guage
Old Jul 22, 2009 | 09:37 PM
mr bill's Avatar
Hate to ask but when did you last change the fuel filter.
Old Jul 22, 2009 | 09:42 PM
Wilbur01's Avatar
I changed the filter about a week ago, so about 500 miles.
Old Jul 22, 2009 | 10:09 PM
WHISTLINTURBO's Avatar
I did the same setup to a girlfriend of mine. Ended up putting a big line kit on and that worked. The light you probably got is supposed to come on when you get lower than 5psi. Flickering i believe means your right around 5psi. I've also wondered if it could be some electrical interference from the something like the alternator. If it is just barely blinking you should be fine. 5 psi is just fine.
Old Jul 22, 2009 | 11:20 PM
KennyG's Avatar
Most important with our trucks is ....FUEL GAUGE
12valvin
Sep 24, 2013 11:40 PM
TankerIP
Oct 9, 2008 08:58 AM
mr4spd69
Apr 10, 2003 11:22 AM
