47re running back on limp mode
Old Jul 21, 2009 | 07:53 AM
fahtb0y's Avatar
I just got the trans serviced 2weeks ago. Torque con, governor pressure sensor, and i think some bands replaced. Driving to work this morning, no excessive hotrod crap, and it drops to third gear from 40mph and din't move the next 7 mi. I read something about cycling the ignition 3 times to see trouble codes but I couldn't get anything to come up. Does anyone know exactly how to check, im not the brightest of bulbs.
Old Jul 21, 2009 | 08:29 AM
sheriffav8r's Avatar
Check your fluids first. Do a search here to find the right way to do it. If you have a digital odometer you turn the key on, but don't start, off, on again, off, on again and leave in on position and the computer will display codes in the odometer window.
Old Jul 21, 2009 | 12:10 PM
RowJ's Avatar
I don't believe the "Key Trick" works on the 98.5's!
Check fluid level warm and in neutral...while running. Anything else will read higher than really is.
'fahtb0y' - You saying it now starts out in 3rd gear...from a stop? Will it shift from there to OD?
That's unusual but still sounds like a bad Govenor Solenoid. They usually start out in second, but shift ok after that.
What happens if you go through the grear manually?
RJ
Old Jul 21, 2009 | 12:12 PM
fahtb0y's Avatar
See, now it will go through the gears and take off decent but it struggles going upwards past 40mph. I'm lost here.
Old Jul 21, 2009 | 12:20 PM
RowJ's Avatar
Sounds like a fuel flow problem? Changed fuel filter lately?
RJ
Old Jul 21, 2009 | 01:28 PM
Fishin2Deep4U's Avatar
Take it back to the shop you used.
Sounds like something is goofed up!
Dave
Old Jul 21, 2009 | 03:04 PM
fahtb0y's Avatar
but would a dirty fuel filter cause the trans to go into survival mode?!
Old Jul 22, 2009 | 01:05 AM
I sure don't know how, but I will never say never!
Dave
Old Jul 22, 2009 | 07:32 AM
RowJ's Avatar
Thought you said it was shifting well now?? Just won't go over 40.
I guess Tranny is still a problem?
RJ
Old Jul 23, 2009 | 06:35 AM
fahtb0y's Avatar
I have no idea what the hell is going on, it's running fine now. Even a little better after that one hiccup, even the garage door opener works on just one click now.
Old Jul 23, 2009 | 08:39 AM
dozer12216's Avatar
Since you admit to not be brightest bulb, do the smart thing and take back to shop for their expertise.
Chemical
30
Apr 30, 2026 08:56 PM
MDMIKE
Feb 26, 2014 05:29 PM
fahtb0y
Dec 17, 2009 07:32 PM
Purist
15
Feb 23, 2008 03:44 PM
ratat98
17
Jun 8, 2007 11:46 AM
