New transmission leak with ATF+4
Old Aug 30, 2009 | 07:33 PM
roysleight's Avatar
I'm wondering if anyone has had this experience. I changed the fluid and filter as usual but changed to ATF+4 this time from the ATF+3 that has always been in it. I now have a transmission fluid leak from the rear transmission seal...coming out between transmission and transfer case. Could the fluid switch have affected the seal? Is ATF+4 thinner at running temp? Any thoughts? Thanks.
Old Aug 30, 2009 | 08:08 PM
hotdram's Avatar
Not sure, but sounds like ATF+4 is correct:
Click Here
ATF+4® is approved for use in older transmissions and is currently utilized in newer Chrysler®, Jeep® and Dodge® vehicles. The previous MOPAR ATF+3® formulation was discontinued in 2005 and ATF+4® is recommended for all transmissions filled with ATF+3®. Only certified ATF+4® is recommended for service of Chrysler LLC vehicles. The use of automatic transmission fluids other than ATF+4®, including those claiming to be like ATF+4®, could result in lower levels of performance, jeopardize transmission life and void warranties.
~Rob
Old Aug 30, 2009 | 10:12 PM
nickg's Avatar
ATF did not cause the leak...bad seal is at fault, most tranny places RTV the TC to the tranny, so when the seal goes it does not leak thru the weep hole.
Old Aug 31, 2009 | 09:32 PM
roysleight's Avatar
Thanks guys, I wouldn't think that the change of fluid would do it but strange things do happen. Must be just a coincidence that it decided to leak now. Is replacing that seal a DIY'er or would it be advisable to take it to a shop?
Old Aug 31, 2009 | 10:07 PM
D2 Cat's Avatar
It's easy and simple to change. Just be sure to have your wheels blocked so your truck does not roll when you remove the drive shaft.
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
troutdog
Nov 27, 2003 12:55 PM
