New Pump Bad ?
New Pump Already Bad ?
Installed new lift pump...Idle pressure 11#...60 mph 7#....Wide open, I let off when pressure gets to 5#...will probably drop to 0#. New pump has 20 miles on it. Did I get a bad pump or is there something else that needs to be checked ? Thanks..
Installed a new filter along with the new lift pump. Electrical connections seem ok...pump does the 30 second run when the starter is bumped...pressure takes a nose-dive when the motor is started.
you will also want to check your fuel restriction at the inlet to your lift pump. if you have a high restriction , you will see less psi from the lift pump. check it at high idle, you will also want to check for air in the fuel.
loveturbowine
Jul 26, 2005 05:50 PM
