new fuel pump
new fuel pump
Well I have my new pump installed. I have 13 @ idle and it will drop to about 7# WO. Is this normal? What is everybody else running. Oh yea and 11# at cruising speed.<br><br>Thanks, <br><br>Kimrey
Re:new fuel pump
When I changed my lift pump, the new one gave me a solid:
15psi @ idle
13psi @ cruise
11psi @ WOT
These pressures are flat ground, running empty.
Have you changed the fuel filter?
There have been some "out of the box" failures of brand new pumps..
15psi @ idle
13psi @ cruise
11psi @ WOT
Re:new fuel pump
Shovelhead, I changed my fuel filter about 10k ago. It could be that. I didn't think it would loose no more than a pound across the filter. I have also thought about this. I had to use the grease gun hose to mount my gauge. Would I loose some through the hose to the sending unit? This pump is supposed to be the most up to date one. The dealer had to order it.<br><br>Kimrey
Re:new fuel pump
The pressue should remain constant even through the rubber hose.
The new pressures just seem a tad low to me. [undecided]
If it was me, I'd try a new filter just for "giggles and grins" to see if the pressures came up some.
Don't get the filter at the dealer though.
Go to Cummins and save about $30.
Re:new fuel pump
Yea, I get mine at Genoe's. I guess I need to give them a call! I was thinking the same thing, that the numbers were a tad low. Oh well, I can keep driving it and change the filter, but keep an eye on the o'l gauge. <br><br>Thanks,<br><br>Kimrey
Re:new fuel pump
Hi Kimrey, after seeing your low fuel pressure in ashville a few weeks ago ordered fuel pressure guage and at idle when warm is 13psi wot 9 psi with new fuel filter. But when truck cold first thing in morning drops to 6psi and 0 upon accel. After it warms up goes up to 13 again after 20 to 30 minutes of driving. Stopped by dealer and they ordered new pump today.
Re:new fuel pump
Cool. I've notice that pressure is about a pound or so low when its cold, but not that low
. Let me know what your new pressures are when you get the other one on. It was good seeing you again in Ashboro. Merry Christmas ALL!!!<br><br>Kimrey
Re:new fuel pump
You must have the same pump I do. Those pressures are identical to mine. Except I get those with all of my banjo bolts replaced. The Holley Black is sitting in my room right now, waiting for the installation kit.
iamallcanadian
Mar 8, 2011 04:39 PM
camerd18
Aug 21, 2008 07:20 PM
Commatoze
19
Aug 8, 2004 09:57 PM
