New FP gauge 8psi @ idle
Old Aug 19, 2006 | 07:46 AM
mike6256's Avatar
I just got done installing a FP gauge and I am only getting 8psi @ idle. Driving down to 3 WOT. The truck just got a new LP (for the second time) and a VP44 800miles after the LP.
What to do next? Could the LP be bad already?
Old Aug 19, 2006 | 08:10 AM
dieselfan's Avatar
you need a pusher pump or fass. i get 8psi when i unplug my holley, 21-24psi with it. vulcans big line kit will help also. here the ph# 360-713-1549 erik, super nice guy will explain everything to you. dieselfan
Old Aug 19, 2006 | 09:18 AM
mike6256's Avatar
What kind of price did you pay? I was looking into the fass but don't have the funds currently.
Old Aug 19, 2006 | 01:00 PM
blackdiesel's Avatar
Registered
when you say new lift pump, is that a intank model? if so then that's about right. Dad has one in his truck and I installed a holley blue helper pump, now he can't pull it down past 15 psi
Old Aug 19, 2006 | 07:29 PM
mike6256's Avatar
I believe it is, I asked them when they told me they were putting in a new LP if it was and they looked at me like I had three heads. 800 miles later when I had new VP44 intalled (differant dealer) they told me it was "the new style LP". So I assumed that meant in the tank. It was quite the run around getting everything fixed.
Old Aug 19, 2006 | 09:22 PM
dieselfan's Avatar
i paid about $230 from jegs for bully dogs big fuel kit, which is a holley blue with 1/2" lines from tank to lp. i m sure if you looked you could get a holley a lot cheaper, then get vulcans relocation kit for 69.95 or the big line kit which does away with the banjo bolts for 129.95 and come out alot cheaper than i did. dieselfan
Old Aug 20, 2006 | 04:38 PM
Beeram305's Avatar
Ok, sorry to kinda hi-jack the thread, but I'm havin the same problem, 6-7 psi at idle and the pump is a month old. It is an in tank pump, what can I do to raise the pressure? Can I or how can I put a pump in line with the in tank pump?
Old Aug 20, 2006 | 04:57 PM
Registered
YES, read post #4
CLeger67
Jan 10, 2008 08:05 PM
S.Dodge
15
Mar 15, 2007 07:55 PM
skymiles
Dec 21, 2006 10:05 PM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
