need help with code??? HELP
ok ni was JUST driving my truck and some wierd looking valve looking thing comes up (lights up) on the dash by were the odometer meter button is so i then did the turn the key on and off 3 times and a code of p 1693 comes up whatas this????? HELP
ive had that one too, after i installed my edge juice its a code that has something to do with the pcm in my case i didnt have the map sensor hooked up all the way causing that code once i pluged it back in it went off. It could also mean you are have pcm issues too if Im not mistaken
Try here...
http://www.allpar.com/fix/computer-codes.html
O.T
Sep 6, 2007 06:10 PM
CTD NUT
Apr 5, 2005 04:45 PM
stack_climber
Feb 23, 2004 02:22 AM
