my truck is dying under a hard pull
Old Jun 12, 2008 | 11:43 PM
edy's Avatar
edy
i think im not getting enough fuel. it runs good for a few seconds and then will just die. thats with a ford power stroke dually hooked bumper to bumper. any help i got a pull tomorrow my first. i got another pump i can run.
Old Jun 13, 2008 | 10:13 PM
badme's Avatar
You are probably doing just that, running out of fuel. Fuel pressure will lie!! Fuel pressure gages measure any pressure including air pressure. If I was going to check this I would tap into the fuel line with clear hose and run a loop of it out by the wipers and back to the vp44. Then hook it to another Ford or a tree or something and give it a pull. I bet you will see air in the line when it dies. If I an right let me know and we can discus diagnosing it.
Old Jun 13, 2008 | 10:44 PM
lloydster's Avatar
check for cracks in your exhaust manifold especially if it is stock
Old Jun 14, 2008 | 07:53 AM
badme's Avatar
How is a cracked exhaust manifold going to make the truck feel like it is running out of fuel?
Old Jun 15, 2008 | 04:06 PM
lloydster's Avatar
my crack(lol) is about 2 inches in a bad spot right at the inlet(middle) apparently any pinhole may make a difference on you losing boost b4 the turbo. have the parts in hand just need to find the time!!! hopefully it holds on till then!! lots of force /pressure lost due to that flaw. if you find one fix it! did you get a 'slip' of about 300rpm? if so that was your electonic tranny sensor heating up and releasing your torque lock due to low boost /high heat on gauge. i do not claim to be expert but thats what i heard and where i am starting when i find time!!!!@! hopefully it is not anything more expensive!!
Old Jun 15, 2008 | 07:21 PM
badme's Avatar
Even without the turbo the truck should not die. Have no power yes, but die no.
As I understand it the truck runs good then dies( as in motor not running).
Old Jun 16, 2008 | 05:31 AM
lloydster's Avatar
sorry man my bad, did not realize you def of die as in restart. i,ll read more b4 posting!
Shoemaker907
Apr 7, 2011 04:19 PM
bahama bob
Feb 13, 2008 02:21 PM
5.9Excursion
19
Oct 10, 2007 06:53 PM
Jambbii
Dec 30, 2005 02:37 PM
D.T.O.
Jul 27, 2004 07:19 AM
