Is my boost pressure correct ?
Old Mar 30, 2005 | 04:12 PM
Valv's Avatar
I just installed a boost gauge, and found out my max boost is at 17lbs. I read the specs for my truck and it says 20.6lbs max. Where are my 3 lbs missing ????
I checked all the hoses, cleaned up IAT but haven'e messed with MAP
What controls pressure, and is it possible to increase it ?
Thanks
Old Mar 30, 2005 | 04:54 PM
dieselrob's Avatar
depends on how your running the truck for that reading. If your towing a good load you might see the 20 or if empty up a grade you can prolly do it but empty on lever ground you will have a hard time puttin enough load on the truck .
Old Mar 30, 2005 | 05:40 PM
MARKY MARK's Avatar
Valv,
I have a '99 also and I can only muster up 17 psi too. Haven't tried checking while towing since I have towed very much yet.
Mark
Old Mar 30, 2005 | 05:57 PM
phox_mulder's Avatar
The wastegate isn't an exact science, things get old and rusty, worn out.
Also, the guage might not be dead on accurate.
phox
Old Mar 30, 2005 | 06:15 PM
tool's Avatar
I'm kinda jealous, mine keeps throwing a code saying I'm boosting 36 psi +
Old Mar 31, 2005 | 10:49 AM
dssimecek's Avatar
Don't know if any thin g on my truck is old rusty and worn out, But that is how I feel somedays.
Old Mar 31, 2005 | 11:23 AM
paulb's Avatar
Re: Is my boost pressure correct ?
Thanks
On a stock truck (without a boost fooler), you will set a code if the boost goes above the max (20.6). That's where the max value comes from. If I remember correctly, when my truck was stock (it's been awhile), that was about the boost I was making.
Paul
Old Mar 31, 2005 | 11:29 AM
Valv's Avatar
Ok, thanks everybody, I was checking if everything is fine.
roughstock
Jan 13, 2014 06:35 AM
joem
Jul 23, 2012 01:34 AM
Katmandu
20
Mar 22, 2006 03:26 PM
jnck
Mar 26, 2005 11:32 PM
ckennedy
Nov 15, 2004 12:27 AM
