motor cutting out and weird peddle
Old Dec 6, 2006 | 07:13 PM
rich's Avatar
we got a 98.5 that keeps cutting out replaced the apps with a used one and it has a holley blue on it. its gets a weak peddle not a dead one and sputers some and will throw blue smoke like its a fuel problem. we have reset the apps so it is not a reset problem. any ideas would be helpful
Old Dec 6, 2006 | 07:32 PM
Copenhagenjunkie's Avatar
It probably is a fuel problem, exact same symptoms I had when the ip went south. The lp is probably bad too. If you don't have a fuel pressure gauge get one.
Old Dec 6, 2006 | 07:45 PM
dieselrob's Avatar
Get the codes check and go from there befor you throw a bunch of money at it.
Old Dec 7, 2006 | 10:11 AM
Gotlift01's Avatar
Have your fuel pressure checked.....it's possible your injector pump might be taking a dump on you
~Nick
Old Dec 7, 2006 | 02:06 PM
jg7103's Avatar
Rich, had the EXACT problem and i got a 99 haha goin to pick it up from the mechanic now he said he changed the fuel filter and cleaned the lines cuz i geuss they were clogged and dirty and he says it runs fine ill post back when i find out for sure
Chrisreyn
Jun 5, 2007 06:23 AM
roughstock
14
Mar 26, 2006 02:30 PM
Rganser
Dec 22, 2005 07:53 AM
Bad Ramer Jamer
Dec 9, 2005 06:56 PM
ozark diesel
Dec 9, 2005 06:04 PM
