moter rebuild cost
Old Sep 13, 2004 | 02:16 PM
nate's Avatar
moter rebuild cost
hay yall i was wandering about how much does it cost to rebuld a stock moter? my brother has a 92 f250 with 250000 miles on it an he said that it going to cost him 2500 to 4000 grand to do his moter. so i was wandering how much it will be for my 2000 dodge diesel. thank for the replys
i rather be cunnin than stroken
Old Sep 14, 2004 | 08:22 AM
BIGHEAD's Avatar
Nate I will say this, I just planted a new CUMMINS RECON in my truck for 8600 bucks. The cost of the motor was 5990 & the rest was labor, & shop supplies. These ISB engines are not the best to rebuild. REMEMBER this, the word REBUILD can take on several different meanings depending on exactly what you need fixed.
Are you now having problems that concern you, if so what are they? You will notice that I put the RV275 engine back in my truck. It only cost a 200 more bucks than the dodge cummins. After I figured up labor, machine shop, parts,etc, it was cheaper to do the recon, which comes with a 2 year unlimited mileage warranty. You can't get but up to a year on a rebuild & it may not cover everything.
Old Sep 16, 2004 | 07:32 PM
Haulin_in_Dixie's Avatar
Bighead I never saw a response... how do you like the 275?
Old Sep 17, 2004 | 09:45 AM
nate's Avatar
moter rebuild
i like it ok but what is a recon moter i never heard of one of those moters. what the diffrence in therecon an what i have?(factory moter)
Old Sep 17, 2004 | 11:49 AM
A recon motor is factory reconditioned by Cummins. Or rebuilt to original specs by Cummins.
Old Sep 17, 2004 | 09:33 PM
BIGHEAD's Avatar
HID I haven't had a chance to dyno it yet. I honestly don't know if I can tell a difference or not. I hope to put a different set of injectors in it this weekend & see what happens. I will know the difference when I can dyno it, because I had dynoed my old one. I know it is a better engine than what the dodge cummins is, because of the higher specs it is built to. I have not had any problems with it at all. It was a good install by the CUMMINS guys. NATE if you have to get another engine, go to CUMMINS & GET IT. They will stand behind there products much better than the usual rebuild shops that will blame you for their failures & short cuts.
Old Sep 17, 2004 | 10:01 PM
You will have more torque, especially on the lower end, which shows up fast on pulling a load. You should also be getting a little better mpg. Both that I had (and have) had a little different exhaust note, lower. I noticed it and those who hear the truck as I pull in and out of the auctions comment on it, but I have a straight pipe. You should have teflon coated piston skirts and harder valves. The cam is advanced just about one tooth on the gear. I run the EZ and of course the rm275 injectors and the difference is quite noticable pulling.
Old Sep 18, 2004 | 08:31 AM
Dieseldude4x4's Avatar
$10,858.00 to do what I had done.
Old Sep 18, 2004 | 09:59 AM
BIGHEAD's Avatar
DIESELDUDE, what did you have done? I paid 5995.00 for the crated CUMMINS RECON RV275 & around 1600. in labor & misc. shop stuff. I had 8600 bucks in mine
with a 2 year unlimited mileage warranty. I know you can't get that kind of warranty from CHRYSLER or any other diesel shops. So please explain what you had done. My CUMMINS serv. mgr told me it would cost me more for them to rebuild than to drop in the RECON, & he could only offer 6 months warranty on labor & 1 year on parts. Is that the route you took? Hey HID if you want to turn some heads, you should here these straight duals of mine. I have 3 inch straights Y-ed right below the turbo turn down pipe. I have been gonna go to 4 inch duals but don't see any real advantage to doing it. I am going to wait until I buy a new turbo first, than I may put the 4 inch duals on. I haven't checked my mileage any because I keep my COMP on 5x5. I guess I like to see fuel mileage in the form of 2 blacks whirlwinds coming out of my tailpipes. LOL
48snowman48
Dec 11, 2007 07:28 PM
u.s mma
Nov 5, 2007 07:10 AM
killed300ex
Sep 6, 2007 04:32 PM
strean
Dec 11, 2005 09:10 PM
