missfire?
Old Aug 4, 2011 | 08:22 PM
bigsmokey's Avatar
missfire?
so i though my tranny was slipping or the torque converter was slipping but today i got on it a little and at higher rpm with the edge on level 5 the truck seemed to misfire. So now i am thinking that the tranny isn't the problem i think the truck has a intermitent missfire. I did an injection pump recently so i don't think its that, so next i am thinking i might have an injector starting to go bad. what else could be the problem any other ideas or simple things to check first. I have been wanting to upgrade to bigger injectors but have been waiting to save some money first but this would be a good reason to do it now. Any thoughts and advice is appreciated.
Old Aug 6, 2011 | 08:30 PM
bowtoot's Avatar
Did it feel like just a little bump? I am experiencing similar and am looking for a cause.
Old Aug 8, 2011 | 11:06 PM
bigsmokey's Avatar
the whole truck kind of shutters a little so maybe like a little bump. anyone have any ideas?
Old Aug 9, 2011 | 09:36 AM
RVTraveling's Avatar
Mine misfires cruising down the road with the fifth wheel trailer. It does this when under a slight load just above maintaining speed (60 mph),like up a small incline. if I get on it, it's not as bad, or if I let off, it's not bad. I can't detect it driving solo without a load. I put new RV275 injectors on and just installed a new VP44. Did not fix it. In fact, after installing the injectors, I had to remove the BD chip because the problem was worse and it ran smoother without it.
I have searched hundereds of threads on many forums and found no solution. Lots of people have the same issue but nobody seems to have fixed it.
By the way, my truck is a 6 speed so I know it's not a transmission problem.
I Think it's a timing issue, I'm thinking of changing the ECM.
Ken
Old Aug 9, 2011 | 10:07 AM
high bid's Avatar
I'd clean the %$^&#! out of all my grounds and make sure all batt connections are clean and tight.
Old Aug 9, 2011 | 12:34 PM
olddodgetrucks's Avatar
Ok mine was doing the same thing,after lots of looking it was just the a/c cycling,who would think the a/c would cause a slight miss on a diesel .
Old Aug 9, 2011 | 01:36 PM
Already done. Did not help.
Old Aug 9, 2011 | 03:46 PM
high bid's Avatar
^ Excellent.
I'm not saying this would happen but I've seen an a/c compressor going bad....stall a 4cyl.
Old Aug 11, 2011 | 09:33 PM
bigsmokey's Avatar
ok i will try cleaning my grounds. my truck has seen some mud so theres a good chance there is a dirty ground wire or two. I have been paying closer attention to try and narrow it down when it does it more it seems to do it when the motor is on the cold side not a stone cold motor but before the t-stat has had a chance to open and like while the tranny temp is still below 120ish i don't know if any of this info makes a difference but who knows. thanks to all for advice.
AndyD
Dec 9, 2009 10:50 AM
JOESHTRDDSL
May 5, 2008 11:04 AM
curts99
Oct 31, 2007 08:50 PM
edy
Feb 24, 2007 08:06 PM
kidder
Dec 29, 2002 06:30 PM
