missfire
Old Oct 30, 2007 | 07:55 PM
curts99's Avatar
missfire
after installing the mach 4's i have a missfire at high rpms. it seems to do it somewhere between 2500-3300 rpms. any ideas, not enough fuel, stock lift pump not supplying enough. it never did this with the jammer 4's. this is with the comp on i havent tryed it with it off yet.
Old Oct 30, 2007 | 08:36 PM
curts99's Avatar
anybody have an idea?
Old Oct 30, 2007 | 09:59 PM
Big Blue24's Avatar
Do you have fuel pressure gauge? What kind of psi are you maintaining. Sometimes the wastegate will blow open and flutter a bit causing the feeling of a miss. Try a pair of vice grips on the boost line and see if it still does it.
Old Oct 30, 2007 | 10:00 PM
curts99's Avatar
im also only making 35psi of boost i was making 38-40 psi with the jammer 4's. no fuel pressure gauge
Old Oct 30, 2007 | 10:33 PM
Big Blue24's Avatar
Did you check all of the injector line connections at the cross over tubes in the head, if you see fuel, you've got problems right there.
Old Oct 30, 2007 | 10:51 PM
curts99's Avatar
no fuel leaks everything there is good. after work tommrow im going to try and eliminat some possiblities. i also did intercooler boots at the same time as the injector change
Old Oct 31, 2007 | 07:58 PM
curts99's Avatar
any other ideas
Old Oct 31, 2007 | 08:50 PM
mysterync's Avatar
I'll bet money you didnt get eaither an injector seated well or you have a leaking connector tube! You might slap some new o-rings on the Connector tubes ...
( For dis-belivers, Yes o-rings on the tubes if bad or missing will cause hard starts and fuel leaks, It lets the connector tube move causing a bad seal)
Its not somthing someone will be able to diagnose easily online!
im 99% Positive you have ,
1 A Loose fitting or fuel leak
2 Air in a line, (low possibility if ran for any period of time)
bigscout2b
Mar 24, 2010 08:15 PM
AndyD
Dec 9, 2009 10:50 AM
JOESHTRDDSL
May 5, 2008 11:04 AM
edy
Feb 24, 2007 08:06 PM
kidder
Dec 29, 2002 06:30 PM
