mileage ? again
Old Apr 26, 2003 | 07:31 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:mileage ? again
Have you tried cleaning the IAT sensor? {Intake Air Temperature}
Some have found their lost milage improved after a good cleaning.
Instructions here;
http://www.dodgeram.org/tech/dsl/sensors/IAT/clean.htm
Hope this helps.
Ed
Old Apr 26, 2003 | 10:42 PM
rich's Avatar
Re:mileage ? again
have you checked your fuel pressure to see if your lift pump is up to snuff
Old Apr 28, 2003 | 10:14 PM
MARKY MARK's Avatar
Re:mileage ? again
Happy. I had the same problem. My highway mpg steadily went down to 15 & town mpg went to 11.5. Then I installed a fuel pressure guage. Fuel pressure was 7 psi at idle, 5 psi cruising & 2 psi WOT. I changed the lift pump & now I am at 19.5 highway, 15-16 city. I am happy now. ;D
Old May 11, 2003 | 08:25 AM
dcwm's Avatar
Re:mileage ? again
Seems we have to educate the dealership as to what to do with fuel pressure. Service manager at our local place argued that the pressure from the lift pump should rise as demand increases....is that right? If so then they will be changing a BUNCH of lift pumps!
I checked my L.P. first time yesterday...6@Idle--0@WOT
Old May 14, 2003 | 02:12 PM
HOHN's Avatar
Re:mileage ? again
The dealer is 100% wrong. The lift pump only has two operating modes: starting and running. When you are cranking the engine, it delivers about 5psi. It's supposed to be 15 psi otherwise. Measured pressure will go down as demand increases. It's basic physics. I will post why when I get to my post from the TDR (not gonna retype that sermon)<br><br>Hohn
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
chuck3
Feb 1, 2005 07:47 AM
gunracer1
18
Nov 24, 2003 08:56 AM
Sean S
Nov 15, 2002 12:25 PM
