LSD Friction Modifier...
Old Apr 16, 2007 | 01:48 PM
JyRO's Avatar
Guys - I swung by the Advance Auto Parts store yesterday and was checking out the rear diff oil and friction modifier.
The only friction modifier I saw available was this stuff called,
Posi-Trac
Limited Slip Gear Oil Additive.
It looked pretty generic. I guess friction modifier is friction modifier. Has anyone used this? Is this stuff good enough? Or should I find something else? Thanks.
- JyRO
Old Apr 16, 2007 | 06:12 PM
bent valves's Avatar
I bought some Trans-X Posi-trac from Autozone and used it in my Dana 80 LSD with good results. I found that using a little less than 1 tube works well with my Mag Hitec diff cover and 5 qts of Mobile 1.
Old Apr 16, 2007 | 10:48 PM
Huff nPuff's Avatar
Just my opinion, the Ford limited slip additive is the best friction modifier out there.Be really careful the sfuff really smells bad,dont get it on you.You'll need 2 bottles for your truck.
Old Apr 17, 2007 | 03:03 AM
wcbcruzer's Avatar
Right now you can pick up Royal purple gear oil for $10.11/quart shipped to your door. No tax. www.karlracing.com. No friction modifier required with that stuff. Might be worth it for you. I just got mine.
Old Apr 17, 2007 | 08:06 PM
Huff nPuff's Avatar
Ive used many of the different synthetic gear oils out there and have always had to add a friction modifier to keep the cluthes from chattering.When they chatter you can do some damadge.
Old Apr 17, 2007 | 08:18 PM
wcbcruzer's Avatar
Oh yea? It says you don't have to use any on the RP bottle. We'll see...
Old Apr 17, 2007 | 08:24 PM
crobtex's Avatar
I don't believe in taking chances........I get my from my local Dodge dealer. Why gamble on something that costs less than $10?
Old Apr 17, 2007 | 09:25 PM
JyRO's Avatar
I'm going to wind up running Mobil 1 synthetic 75W - 90. And I WILL be running friction modifier regardless. I'm just trying to find out if there is a specific friction modifier that is recommended, or the stuff I mentioned if fine.
- JyRO
Old Apr 21, 2007 | 03:40 PM
ib516's Avatar
If you tow with your truck, you should use 75w140 synthetic - so says the manual for my truck - a 2002.
Old Apr 21, 2007 | 07:56 PM
wcbcruzer's Avatar
So should I run a friction modifier with my Royal Purple or not? Could that make it too slippery?
Old Apr 23, 2007 | 12:21 PM
JyRO's Avatar
Let's see, I've got 118k+ on the truck now ... and it has the original diff fluid. I would say my truck has towed (rather heavy) for 2/3rds of those miles. Don't take this the wrong way, but why *should* is use 75W-140?
Personally, I think that I'm fine with conventional 75W-90. But I've decided to run Mobil 1 synthetic 75W-90. That should be more than adequate for my application as far as I understand.
- JyRO
fredbert
Feb 23, 2008 03:23 PM
arroyojim
Apr 5, 2007 12:19 AM
MARKY MARK
Jan 17, 2007 03:29 PM
I PASS GAS
Jun 12, 2006 08:40 AM
Crimedog
Jun 22, 2005 04:37 PM
