Friction modifier quantity vs. LSD performance
Old Jun 8, 2006 | 07:45 PM
I PASS GAS's Avatar
Fixing to change the fluid in my rear end.
I've got the right amount of oil, but am confused about the friction modifier. The manual says 7 ounces, but I've read some of you guys put as much as 10 ounces. What are the effects advantages/disadvantages of putting a little more/less.
I tow about 4,000 a few times a month. My trailers are parked out in the grass so when I got to get them after a rain, having the LSD perform as good as possible is helpful. Also helps to have it in good shape out on the boat launch too.
On Edit to the original thread: I bought the Royal Purple 75W-90. It says it already has aditives in it for LSDs. Do I still need to add more, or go with what the manual says. Why do things have to be so complicated???
Old Jun 8, 2006 | 11:01 PM
rfcom's Avatar
If you put too much in, the clutches will be too slippery and the LSD function will be compromised. Too little could cause chatter when taking corners. With either the RP or Amsoil SVG, you don't need to add the modifier.
Jim
Old Jun 9, 2006 | 08:57 AM
johnh's Avatar
lsd
don't be confused, put your oil in & see how it works.... i use red line, no problems my lsd works perfect
Old Jun 12, 2006 | 08:40 AM
VADSLRAM's Avatar
Jim
I used Amsoil and about a month later started getting chatter. I called my dealer hotline and they said sometimes it's still needed so I got some modifier. a week later all chatter gone. I used all that was in the tube I bought, dunno how much that was cuz i threw away the tube.
fredbert
Feb 23, 2008 03:23 PM
JyRO
Apr 23, 2007 12:21 PM
arroyojim
Apr 5, 2007 12:19 AM
MARKY MARK
Jan 17, 2007 03:29 PM
Crimedog
Jun 22, 2005 04:37 PM
