Lp question
Old Sep 16, 2007 | 04:25 PM
Purplezr2's Avatar
Lp question
Ok, I figured since I was new to the truck I would replace the LP just so i was safe, I looked for it and it appears there is just an AL block in its place. Then I noticed a sticker on the core support that says something like "The fuel system on this vehicle has been alter from its original form" or something along those lines. Does this mean I have an intake pump, and if so what upgrades should I make to protect my VP44
Old Sep 17, 2007 | 12:17 AM
bentwings's Avatar
Look down along the driver side of the frame on the inside about even with the back of the cab. You will probably see a non stock lift pump of some sort. Try taking a picture and post it so we can help identify it. If it's not there you probably have an in-tank one installed by a dealer.
Also fill out your sig in user cp so we can help you more.
Old Sep 17, 2007 | 03:49 PM
Purplezr2's Avatar
Updated Sig, but can't make it show up, maybe no enough post.
On topic
The fuel line comes from the tank, then goes to a rubber section off the frame rail in the engine bay to an aluminum housing that sits were the LP should be(from my understanding) then there is a banjo bolt on the other side of the Aluminum block that goes in to the FF assembly.
Tank looks some what new and has a fresh looking sticker on it. It the tank replaced as part of the intank pump.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
