low range 2 WD
Old Jun 3, 2005 | 09:00 PM
jrsgrounded's Avatar
low range 2 WD
I tow very heavy from time to time (25000lbs.) and could benefit from using low range in tight areas without 4WD. Does anyone know if my 2002 4WD 1 ton auto can be rigged with the 2 wheel drive low kit that works off of vacumn?
Old Jun 3, 2005 | 10:25 PM
BIGBADBOB's Avatar
Check this thread. 2LOW
Old Jun 3, 2005 | 10:37 PM
phox_mulder's Avatar
Also depends on if your 2002 has the central axle disconnect, or if it's a late 2002 with the solid front axle.
phox
Old Jun 5, 2005 | 08:54 AM
How do I determine if I have the solid front axle or the central axle disconect? I ordered my truck in late March of 2002 and took delivery in May.
Old Jun 5, 2005 | 04:30 PM
Definately a 2002.5 then.
If you want to make sure, check the front axle for a box looking thingamajig mounted on the axle tube with 2 vaccum lines and a couple of wires coming out of it.
phox
Old Jun 5, 2005 | 05:37 PM
tankeryanker's Avatar
2001.5 was the last year model for the cad. I have a two low kit on my truck but my buddies 2002 couldn't do it without some locking hubs.
Old Jun 5, 2005 | 05:58 PM
Early 2002's still had the CAD.
phox
Old Jun 5, 2005 | 06:09 PM
Sounds like I'm not going to be able to do this without a considerable expense. Does anyone know what is involved and about what the cost would be?
Old Jun 5, 2005 | 07:04 PM
Putting locking hubs on a 2002 runs around $2500 bucks.
Yes, two thousand, five hundred dollars, just for the kit and you lose your ABS.
phox
Old Jun 5, 2005 | 07:26 PM
Haulin_in_Dixie's Avatar
Be cheaper to custom fit a ford front axle in it.
Old Jun 5, 2005 | 07:28 PM
Ouch! Guess I'll do without. Thanks for the replys.
Old Jun 5, 2005 | 07:35 PM
About all I use the 4wd for on mine is the low range. I am seriously considering going to a straight axle from a c and c model. Lighter weight and same results.
OrangeBlackHD
Jun 22, 2010 07:11 PM
Firstgenfanatic
Apr 10, 2008 12:24 PM
Mark Hodowanec
Mar 19, 2007 05:55 PM
fitzer
Jun 25, 2003 07:50 AM
kevinn
Jan 3, 2003 04:51 PM
