Low power, VP??
Low power, VP??
I guess I'll start my own thread, seeing as I dont want to hijack " New VP44 Wow!!!!"
So to recap, My new to me truck has low power (can be beat by a Chev 6.5 easily)
So far
1. new filters, air/fuel
2. Fuel pressure tested Idle 14psi WOT lowest 5.5psi, average 8 psi normal driving, checked pre-filter
3 did the APP relearn (no test drive yet)
4. pulled dash to fix hi-beam indicator, and found that someone had pulled the check eng lite!!! my build date is Mar 2000, can codes be read thru the Odometer? I tried with my snap-on and no codes found. I have not driven the truck since replacing the bulb, I'll find out tomorrow if the truck trips any codes.
5 Truck is making boost at low rpm as it is easily heard since removing the "snorkel" that goes into the inner fender, will instal a boost gauge in a couple of days.
6 no diesel rattle, runs quiet, all throttle positions, even on start up,
7 engine runs smooth, no misses or strange smoke, just dead off the line
I'm thinking I'm gonna need an IP
So far
