Low Fuel Pressure Issue
Old Jun 26, 2010 | 07:59 PM
tspooner3's Avatar
I'm coming home from the store and my fuel pressure goes to zero. Luckily, I was close to home, so I was able to idle home. Anything more than that, truck would miss. Changes the fuel filter, it's clean. Fire it up, I'm getting 13psi. The minute I get on the throttle, it drops down towards zero. Suspect the tank pickup filter is plugged? It's a 99 24valve. Are the pickup filters standard in a auto parts store? Should I be concerned about anything else? Truck only has 88K on it.
Old Jun 26, 2010 | 09:34 PM
birddoctor's Avatar
Sounds like your lift pump is history.Time to start looking for a FASS or Air dog.
Old Jun 27, 2010 | 01:50 AM
big wally's Avatar
Low Pressure
Good luck.
Hope its only the lift pump.
Check for codes, asap..
Try the Fass, they do have a direct replacement pump that plugs right in to original wiring.
I am happy with mine, not as noisy as the big pumps and a lot cheaper.
Also get a low pressure warning light or gauge, insurance and a lot cheaper than a VP44.
Old Jun 27, 2010 | 07:18 AM
tspooner3's Avatar
I installed a new FASS pump approx 2K miles ago.Seems to pump well at an idle
Old Jun 27, 2010 | 07:38 AM
Shovelhead's Avatar
Administrator / Scooter Bum
A hand operated well pump beats the stock Carter.
I went with a Walbro kit.
There are many options in the marketplace to replace the stock pump.
Old Jun 27, 2010 | 08:07 PM
Wyoming Geezer's Avatar
I recently installed a FASS Platinum 95 in my 2001 2500. So far so good. Check out Geno's Garage, I have purchased several itewms over the years and never screwed (to my knowledge) so far from them. I do know that I checked the idle fuel pressure before (<5psi) and after (>15psi), WOT and >25psi boost, still better than 11psi fuel.
As others have said, anything is better than the Carter POS that came on it and I replaced with before I discovered this forum.
Old Jun 28, 2010 | 12:58 PM
Junk Man's Avatar
You may be low on fuel. FASS should hold 13-15# solid. If not, call FASS. Don't drive it with low FP - not even at idle (unless you feel like learning about VP install. (Diesel Dan has video of process on youtube.)
My AirDog will drop to 0 when fuel is low and I go around a corner. I paid for the install & dummy put pick up too high. I've read where this is possible if tank was dropped because bottom of tank will push up when lying on the ground. I now keep 1/2 tank or better.
Old Jul 9, 2010 | 07:03 PM
tspooner3's Avatar
Ok, the latest - I replaced the fuel pickup with a drawstraw (lines were severely corroded and leaking), tank module pick-up screen was spotless. Pump is doing well. Discoverd a new fuel filter plugged (less than 1 mile on the new filter ). Suspect bad fuel. Tested evey component on the truck (replaced all fuel lines, pressure regulator, etc). Tested pump off the truck, good pressure (17 psi - FASS DDRP). Took a full day, but saved the price of a new pump. Need to watch the pressure now - suspect bio in the fuel plugging the filters.
lampltr
14
Sep 2, 2011 12:50 PM
jwb600
14
Jan 28, 2008 03:26 AM
bc3
Dec 1, 2007 10:19 PM
mudwisr2
Sep 25, 2007 07:04 PM
Spooler
Feb 12, 2006 11:43 AM
