loss of all power and truck won't start...
Old Sep 6, 2013 | 11:32 PM
rightwinger's Avatar
I was finishing up bleeding the lines after a new LP install, and had the truck running on 3 cylinders, and then it died. No biggie, I cranked the other lines down tight and went to start it up again and I see a spark and hear a popping at the battery, and then I have no power or anything. I checked the fuses, they all appear good. I had been cranking on the truck for 20 seconds at a time trying to get the lines bled out, and I'm sure this had something to do with it because my battery terminals did get pretty hot, but I am at a loss for what has happened here. any help would be appreciated.
Old Sep 7, 2013 | 10:31 AM
Tallguy67's Avatar
That sounds a lot like a burnt fusible link to me, although I am not sure where they are on our trucks.
Old Sep 7, 2013 | 12:17 PM
SIXSLUG's Avatar
They can "look" fine and be blown...check with a multi-meter or test light.
Batteries as well
Old Sep 7, 2013 | 05:21 PM
Thank you everyone for the help, after checking fuses and connections it turned out to be the most basic....a loose battery terminal that got loose from it heating up when cranking it. Problem solved.
Old Sep 7, 2013 | 10:13 PM
SIXSLUG's Avatar
Good job.
Free fixes always rock!
RHC
Aug 12, 2019 03:32 PM
tntk9
Nov 20, 2012 07:09 PM
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
cbrxxtreme
24
Jul 17, 2008 03:30 PM
