long shift going into second now (AT)
Old Aug 31, 2009 | 04:09 PM
97catintenn's Avatar
99 dodge CTD 4 wheel drive autotransmission
Pulled 7,000lbs Friday with it. Today, it acts like it doesn't want to shift into second. You take off, rpms get up around 2k and truck does something...but it just waits about another 5 seconds before actually engaging into second.
Checked the fluid level, and it's full. After it shifts into second, the other gears work well.
I think I may have damaged something when I was pulling, cause there was one spot that I had to take off at the bottom of steep hill...and it stayed at 2k rpms pulling it up the hill slowly. That, and I've never pulled that much weight before.
Old Aug 31, 2009 | 05:06 PM
ado2b1's Avatar
Pressure governor sensor and solenoid would be my guess. It took about two weeks for my rig to quit shifting into third all together. Same symptoms. No way to diagnose that I'm aware of. If it continues for a couple of days shifting fine 1-2 and 3-4 + OD lock but resisting a solid 2-3 shift I would be almost certain. Check transmissionpartsusa.com for the sensor and solenoid, about half what you'll get them at the dealer for. Make sure you get the right sensor, I ordered the wrong one at first b/c it was listed incorrectly for a 47RE.
The replacement is very easy though. Maybe an hour from start to finish clean up.
Would think it was just coincidence with the towing 7k should be nothing for these trucks, even the notorious trannys.
Old Aug 31, 2009 | 07:11 PM
So, it wouldn't matter that my problem is the 1-2 shift and not the 2-3 shift, right?
Old Aug 31, 2009 | 10:21 PM
dozer12216's Avatar
A delayed or soft 1-2 upshift is frequentlly the result of excessive KD band wear. A adjustment will probablly put you back into business. After proper adjustment at bolt on left upper forward side of case, there should be threads showing above Jamb nut. If no threads show, the band is worn out. Quick repair steps are indicated as the metal of band starts wearing into expensive drum it rides against. Fluid and filter repalce at same time is generally accepted practice.
Old Aug 31, 2009 | 11:07 PM
67HotRod's Avatar
I second this, just hope theres some material left on the band.
Old Sep 1, 2009 | 12:16 PM
bigfish95971's Avatar
On mine it has been the pressure switch and solenoid. twice in 400k
Old Sep 1, 2009 | 05:38 PM
I'll give it try guys! Thanks
Old Sep 2, 2009 | 11:01 AM
Well, I tightened the band up and she shifts like new again!
Thanks for all the hope, and the site, I owe this place alot!
My band is pretty worn, though...I don't think I have room to do another adjustment.
lincolnproberts
Dec 5, 2012 12:13 AM
Lost Lake
May 31, 2011 07:29 AM
IntakeRacing
Oct 28, 2007 10:44 PM
carney
Dec 11, 2006 12:24 PM
angus
Feb 6, 2003 09:16 PM
