Limited slip?
Old Feb 21, 2008 | 08:24 AM
btown647's Avatar
Limited slip?
i have a stock 02 2wd does it have lockers or limited slip?
Old Feb 21, 2008 | 08:57 AM
johnh's Avatar
on mine there is a tag on the diff cover that says what type of lube to use.... if you have any kind of stock LS diff, it will be a trac-lock, which is a clutch operated limited slip differential.... i think also there's a tag on your glove compartment door
Old Feb 21, 2008 | 11:21 AM
smokinram99's Avatar
Look at the EQUIPMENT LABEL (on mine under the hood, back to the grille)
CODE N° DSA: AXLE ANTI-SPIN DIFFERENTIAL that means that you have a Limited Slip Diff.
Old Feb 21, 2008 | 01:36 PM
nitrousn's Avatar
Open was the standard. Clutch type limited slip was an option. As said look for a tag or the listing on your equipment tag.
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
White02Sport
Apr 16, 2003 12:08 AM
NWDave
Jan 25, 2003 06:03 AM
Srigs
Nov 13, 2002 09:30 PM
