Dodge Limited Slip codes on the sticker?
Anyone know what the code is for Limite Slip on the sticker under the hood for a Dodge 2500 4X4?<br><br>Thanks in advance, Srigs
Re:Dodge Limited Slip codes on the sticker?
If the truck is equipped with limited slip it should say "Limited-Slip Differential" on the sticker and have a tag on the rear differential being held on by one of the diff bolts that says "Limited-Slip" also.... I'll check the actual code in a couple of mins.
My truck is a 95, so yours might be different, but the sticker under the hood<br>says DSA is the code for limited slip.<br><br>I asked a while back for others to post what build codes they had, but<br>got no responses...<br><br>Hope that helps
For my 3.55 Rear Axle says DMD and Danya 70 DRE for codes.<br><br>So, looks like it is not limited slip. I guess 4X4 will have to do.
