cold starting
Old Nov 12, 2002 | 10:01 AM
dodgeman01's Avatar
cold starting
My truck has been starting really hard, and sometimes not at all. The batteries are brand new. It seems like the grid heater is not working. is there a way to sheck it? also the other morning I had my truck pluged in and it started the sam as before without being pluged in. [undecided] ???
Old Nov 12, 2002 | 11:07 AM
Alec's Avatar
Re:cold starting
If the battery voltage is not being pulled down by the start cycles, then the grids aren't working.<br><br>Depending on the temperature, and how long you plug the block heater in for, the heater might not make much difference starting the truck if the grids aren't working.<br><br>However, you might have a timing (injection pump) or valve adjustment problem.<br><br>Excessively retarded engines are hard to start.<br><br>Good luck!
Old Nov 14, 2002 | 06:08 AM
berner's Avatar
Re:cold starting
dodgeman01<br><br>The Haynes manual has pretty good instructions on checking the whole grid heater system. All you need is a multi-meter. I just went through mine and ended up replacing the relays under the battery. (one was bad but you gotta buy both together : )<br><br>Have you checked your fuel hoses? Maybe you're getting some air in the system. How's the shut down solenoid? Good luck with it.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Palmetto_kid
Jan 14, 2003 08:22 AM
Hummin Cummins
Nov 18, 2002 12:41 AM
