LiftPump R&R stories
Old Jul 29, 2004 | 04:16 PM
TFGG Motorsports's Avatar
Ok so the LiftPump remove/replace is a big pain in the ****...
im removing bolts and all of a sudden one of them just keeps turning, doesnt really seem to go anywhere so im wondering *** happened...
yea the stud came out of the LP but the nut locking the stud into the top of the LP is still on the other side of the mounting plate...
I am dirty, sweaty and (sarcasm)thrilled(/sarcasm) and if my fuel lines ever get here I might be a happy camper, especially since I am in the midst of moving and am kinda put off by the fact that I have an 8000# paperweight in my driveway.
Old Jul 29, 2004 | 04:20 PM
Haulin_in_Dixie's Avatar
Screw it back in, get a thin wrench on the nut and tighten it, hold it while taking the top nut off.
Or just take the others out and remove the pump, then fix it.
Old Jul 29, 2004 | 04:26 PM
i already got it out, I just used an air hammer to make it cooperate
BTW, for folks replacing the LP, its MUCH easier with the fuel filter canister out of the truck.
Old Jul 29, 2004 | 05:03 PM
Moose10's Avatar
TFGG,
Give us some info on your truck. You can fill out your profile by clicking on the "user cp" button near the top of your screen.
btw, thanks for that tip on the LP.
Old Jul 29, 2004 | 05:21 PM
FastSS's Avatar
Finally sorted out my password so I can use my normal user name at the shop and not cause any more confusion
Banjo fittings, no matter how much cussing is involved, are not easy to work with when you cant see the hole they go into.
I hope that I get my new fuel lines tomorrow which I should unless customs thinks they are WMDs or something... otherwise ill have to improvise with what is left of my stock fuel lines...
Old Jul 29, 2004 | 05:37 PM
Dieseldude4x4's Avatar
I wrote step by step instructions for those that need them and I changed so many, I had it down to about 35 minutes including removing the fuel canister. The instructions are posted in the tech section somewhere.
I don't do no steenking lift pumps no more. I eliminated that problem for good.
Old Jul 29, 2004 | 06:18 PM
gamiller31's Avatar
When you start installing the new fuel lines, remove the intake horn as well as the filter canister mounting bracket. Makes the job alot easier. Be sure to put a rag or something in the intake and intercooler boot. Are you installing the Max Flow kit from Wildcat, or something else.
Old Jul 29, 2004 | 08:04 PM
FastSS's Avatar
Wildcat maxflow
I dont need to take off the intake horn I dont think, I can get to the VP44 banjo pretty easy
Old Jul 30, 2004 | 01:24 PM
FastSS's Avatar
of course nothing beats installing the maxflow kit in the rain =(
Superduty
Jan 25, 2006 12:24 AM
plow
Jan 20, 2006 09:42 AM
boostedte37
Nov 13, 2005 09:21 PM
kwhite4
Feb 10, 2005 10:26 PM
dvp98.5
Dec 26, 2003 03:25 AM
