Lift pump wiring problem
Old May 2, 2007 | 03:24 PM
Stevie G's Avatar
Okay, turns out the lift pump is fine.
Turn the key and you can here the relay pickup.
Swapped relays and the relay is fine.
Is there any chance there is a common failure point in the harness I should check first or am I resigned to hunting for a brake in the wires the good old fashioned way?
I'm happy that the pump is fine but, I'd have been even happier if replacing the relay had done the trick.
Old May 2, 2007 | 03:43 PM
Stevie G's Avatar
Any reason I can't wire the pump through a switch?
Anybody know which wires from the power center go to the pump so I could just run new wires?
Old May 2, 2007 | 09:00 PM
slim51015's Avatar
What year truck?
Old May 3, 2007 | 08:49 AM
Stevie G's Avatar
99 dodge 2500.
Old May 3, 2007 | 05:48 PM
bent valves's Avatar
You may want to think twice about using a switch to power the lift pump. Cummins uses the ECM to control power to the lift pump. The ECM, pins 35 and 15 supply +12 volts to the pump. Two pins are used to provide enough current to the lift pump. The ECM also duty cycles the power to keep the lift pump running at about ½ speed when the engine is cranking. The slower speed keeps fuel pressure below about 7 psi to aid starting. But the reason not to use a switch is because in the event of a crash, the ECM will stop supplying power to the lift pump to prevent a fire if the fuel line gets severed. If the lift pump is powered through a switch it may continue to feed the flames.
Old May 4, 2007 | 09:20 AM
Stevie G's Avatar
so, what colors are 35 and 15.
I'd love to have it work the way it is supposed to but for now, I really need it to run.
If I new which wires to tap / replace, I'd be all set.
My manual is at my shop in NY so I have no wiring diagram.
Thanks again,
Steve
Old May 4, 2007 | 07:01 PM
The wires from pins 15 and 35 are both color coded Yellow with a White tracer. Both of these wires are joined at a splice marked S160 before going to the lift pump connector. My shop manual does not tell me where S160 is located, but I can give you a picture on the ECM connector on the wiring harness. The two pins marked in red are the ones you want.
Edit: Don't be fooled by the pin marked 4. It is really 41. A mistake in the Dodge manual, imagine that.
Old May 5, 2007 | 08:14 AM
Stevie G's Avatar
Thanks!!
This is the plug on the ECM on the block?
Should make things easier.
Txwelder
Nov 26, 2025 01:53 AM
bigdave
21
Jan 29, 2009 06:29 PM
Stevie G
23
Aug 6, 2006 04:27 PM
mulepackin
Jul 13, 2006 05:49 PM
Txwelder
May 19, 2005 06:10 PM
