Lift Pump Replacement
Old Oct 19, 2009 | 09:20 AM
turbo diesel's Avatar
I need to replace the lift pump on my 1999 dodge with banks system. Maybe 300 hp. Which pump can I use I really dont' want to put new draw tubes in tank. Do like the idea of filters and low pressure light on air dog. Do you have to replace draw tubes? Thanks
Old Oct 20, 2009 | 11:27 AM
Smokin98.5's Avatar
On my 98.5 24v I put a FASS on and you don't replace anything from the top on the tank down. Unless you have a intank pump you wouldn't need to replace the draw tubes. Airdogs look good and cost less, sounds like a good choice to me.
Old Oct 20, 2009 | 06:37 PM
samaf's Avatar
On my 99 I replaced the original with a Fass and it was a direct replacement. Only took about 2 hours doing it by myself. Some books say do it from the bottom and to do this you have to take the starter off. I did mine from the top and only had to take the filter off and move it to the side. Good luck
Old Oct 20, 2009 | 08:09 PM
Doj Dewd's Avatar
my vote is for a mechanical LP such as the MITUSA from 'Opie'
Txwelder
Nov 26, 2025 01:53 AM
mstep3
23
Jul 27, 2010 02:22 PM
Txwelder
May 19, 2005 06:10 PM
w4xtc
Mar 14, 2004 09:14 AM
AlpineRAM
Jan 30, 2003 03:24 AM
