Lift pump questions
Old Jul 13, 2008 | 11:31 PM
rdut's Avatar
Lift pump questions
OK what does Dodge take off when they move your lift pump into the tank?? Do the leave the bracket on the block?? What about the fuel lines?? I am going to add the Cummins 4090046 pump back to the system, in addition to the tank pump, to insure a reliable system. All I do is tow with this truck and want to make sure I don't break sown some where if I can avoid it. Also what electrical relay are you guys using when wiring up two pumps?? Does anyone have a diagram? Any additional instructions would be appreciated.
Rob
Old Jul 14, 2008 | 12:00 AM
kruisecontrol's Avatar
IIRC just a bypass hose, the relay harness & a wire that goes to 12v ,
the old stuff stays in there.
Old Jul 14, 2008 | 12:22 AM
Diesel Doc's Avatar
the bracket is still there the mount a ported block of alum in the pumps place on my truck they just taped into the harness running to the tank and put in a second relay. putting a stocker back on should be simple to do
Txwelder
Nov 26, 2025 01:53 AM
realsquash
Aug 19, 2005 08:52 AM
Txwelder
May 19, 2005 06:10 PM
JackRAK
Dec 6, 2003 11:04 PM
015speed
May 14, 2003 09:27 PM
