Lift Pump Puzzle....
Originally Posted by GrampZ
Switched to P4601HP, moved it to frame rail near tank. Used big banjo on filter inlet. Should have seen 18 psi, no? Fired it up and got 10 psi. 10 psi idle and 9 psi WOT. I am puzzled?! Used to see 15 idle and 9 WOT. ??????
Double checked with another gauge, same result. Looks like I'm getting a well regulated but low pressure flow.
Label on pump sez it should be used with Part #XXXXXXX regulator....
I can see a regulator to lower pressure if it's too high. But ***? Parts store has another pump coming tomorrow. Guess I'll try that and see what's up.
Any ideas?
GrampZ
Any ideas?
GrampZ
I got to admit that the 4601HP pump looks just like the OEM LP pump... but I think there is a difference in the internal regulator...
InjuredOften
Oct 6, 2008 09:11 AM
possum
Sep 6, 2005 08:39 AM
